Ca?
jc
01-16-2002 08:47:02
Did any ca's have a 3 spd trans? I just bought a tractor(sorry, don't have serial number handy but I'll look when I get home) It has ca emblems on it, but it has a 3 spd and I've read where the Ca has a 4 speed. It Has a 3pt hitch, foot clutch, live pto. I don't know if its a b with sheet metal changed or a ca with another tranny.
Robert Mull
01-18-2002 04:16:17
 Re: Ca? in reply to jc, 01-16-2002 08:47:02
Here are some more differences : A "CA" has power adjust spin out wheel rims on the back. Also a big spring under the center of the transmission for the drawbar and other implements to attach.There are two holes drilled and taped in the torque tube on the sides beneath the battery box although the late model "B" had these also.The final drives are at a slight angle to the rear.
David Soderman
01-16-2002 16:12:18
In 1951 Allis produced 147 CA's with SFW
steve
01-16-2002 16:11:24
there are several differences between the C and CA. A few of the obvious are the four speed transmission, the CA had a steel "deck" below the seat and above the transmission with the hydraulic and pto levers sticking thru it. The CA had a bucket type seat like the WD45, where the C had a bench seat like the B that goes fender to fender. The CA also had a hand clutch on the right side axle to disconnect power to the wheeles but let the pto run.. Is this what you are calling "live pto". There are alos some differences in the torque tube between the eng and transmission, and the engine serial number could tell you if it was a later model, but these are less noticable changes.
