Allis B running under load
Kyle N.
01-16-2002 08:39:46
I am restoring an allis b and ran into a little problem that hads me stumped. I just got it running after about 13 years of sitting. When it runs it seems to be running under load. I poped off the timming gear cover and it is right on time. I just put a new manifold on it, along with a valve job. Could it possibly be the carb. I know there is no main neddle ajustment just one for the air. What could it be?
Duey (IA)
01-16-2002 09:25:08
 Re: Allis B running under load in reply to Kyle N., 01-16-2002 08:39:46
Kyle, It sounds like you are checking the timing gears for being correctly meshed?? The timing mark is on the flywheel and is viewed on the left side through a small hole. Also makes a difference if your B has a magneto or distributor as to procedure for correct timing. Post back with more information and someone here will give more details. Duey
