D17 deisel series 3
Jim Long
01-15-2002 10:13:26
I have a front loader, no pump. Damper drive for the pump?? I want to convert the old trip bucket to HYD tilt power up and down. any Ideas. would like to hear from more D 17 fanatics.
steve
01-16-2002 16:28:51
 Re: D17 deisel series 3 in reply to Jim Long, 01-15-2002 10:13:26
Jim, ik dont know exactly what setup you have, but your present pump must supply pressure thru a hose to your loader valve. The valve raises the boom. You may have "float" down system, or power down. Either way, you can change out your present single valve for a double valve. One spool for the lift, the other for the bucket. You can purchase valves thru Northern Hydraulics to do this generically or spend $$$ at AGCO. The new valve, dual spool can be purchased as power up and down, single acting (float down), and most can come with a detent so you dont have to hold the spool all the time. Again I dont have a D17 now, but hydraulics are hydraulics.
