Magneto drive slot position at overhaul
lester
01-12-2002 15:04:55
is slot straight across or one tooth off either way
Dick L
01-12-2002 19:53:57
 Re: magneto drive slot position at overhaul in reply to lester, 01-12-2002 15:04:55
Check the pictures # 9 through #12
If you have the timing gears lined up as in the drawing and pictures you will see that the notches in the magneto drive will be streight across.
steve
01-12-2002 17:45:33
lester, what are you looking at. Have you got the plastic distributor cover off the mag, the mag out of the eingine, or are you looking at the gear train in the font engine cover?
