D15 head
Gordon-Tn
01-11-2002 00:06:25
looks like i will need a head for the D 15 diesel. I pulled it off & it has a crack on each side of the intake valve in three cylinders, If anyone has one,I,m shoping. thanks for your help Gordon
tom
01-12-2002 14:41:32
 Re: D15 head in reply to Gordon-Tn, 01-11-2002 00:06:25
is this a Buda diesel, i have a four cylinder diesel.
Gordon
01-13-2002 00:35:01
 Re: Re: D15 head in reply to tom, 01-12-2002 14:41:32
Tom I think this is a 175cid (allis)it has 4512321-5 stamped in a circle around a plug between the two front rocker arm mounts,looks like it was done with a hand number set on a machined surface, on the side where the oil line goes looks like a casting #4512303 with 25 under that # also there is an S with the letter f inside top part and co in the bottom part. I did not find A manufactor I.d or name if the above don,t cover it. thanks for your help Gordon
Wayne(Ont)
01-11-2002 01:36:28
I found a specialty machine shop that repaired
cracks in my WD45 heads. I suspect yours could
be repaired as well.
Diesel Don
01-11-2002 09:17:18
 Re: Re: D15 head in reply to Wayne(Ont), 01-11-2002 01:36:28
I recently found a crack in my 34 Chev truck engine head and a local speed shop did a close inspection of the head, metal spray welded the cracks,refaced the rocker arms,and installed hardened valve seats for about $300.I know this isn't a diesel, but the proceedure to repair will probably be the same.
