D14 Worth fixing???
Trent Williams
01-09-2002 19:32:19
Bought a D14 #16269 Narrow Front end. Was running when I bought it. Engine is worn out. Block has crack between Cyls. #1 & #2. Crank needs turned. Head looks OK. Power steering is good. Hydraulics seemed OK. Tires have good rubber, but have cracks. Trans. would not hold in 3rd (4th ok) What is the demand for my good parts? I have about $850 invested.
Doug
01-09-2002 20:54:53
 Re: D14 Worth fixing??? in reply to Trent Williams, 01-09-2002 19:32:19
Trent, Sounds like a lot of work. Maybe best to replace the engine with one from Worthington Ag or other source, could run anywhere between $1000 to $2000. Could easily make your money back in parts. The D14 is a very good tractor, I have a 1957. I guess it is up to how much you want that tractor. If you do part out, let me know may be lookkng for some parts.
Thanks,
Doug
