W.D. block
R. Farrell
01-07-2002 16:35:13
Can bottom web where sleeves go in be repaired by welding them up.If so how would you go about doing this once motor is out of tractor.
Tom
01-08-2002 18:36:10
 Re: W.D. block in reply to R. Farrell, 01-07-2002 16:35:13
If you mean where the O rings seal, clean all of the rust off and put JB WELD there. Make a ring of sheet metal to make a form to keep it in place while it sets, then carefully file it to shape, trying a liner in often to see where it is still tight.
