D-17
JOHN
01-06-2002 06:31:34
THANK YOU FOR THE HELP ON WD--WD45--WC.COULD YOU TELL ME THE D-17 ALSO STOCK HP CI? DOES ANY ONE KNOW THE CI & HP OF THE COMBINE ENGINE THAT FITTS THESE TRACTORS.
Matt
01-23-2002 19:03:11
 Re: D-17 in reply to JOHN, 01-06-2002 06:31:34
I found some original AC pamphlets at an anitque flee market it said d17 gas had 63 engine hp 54.5 at the belt pulley and i think 46 at the drawbar. Diesel and lp were about 2-3 hp less
GeneD14
01-06-2002 16:35:08
The gasoline engine D17 is a 226 ci The Gleaner E Uses the same basic engine with a different carb, govenor, and fuel pump. HP is about the same 46 hp depending on who you ask. If you put the combine engine in a WC, WD45, or D17 you will need to change the govenor and carb or it won't run correctly under a light load. The combine was designed to run wide open for hours at a time. I have put a Gleaner F 262ci six cylinder gas in a D17 that used to be a diesel. It was alot more work but it produced about 70hp! The D17 diesel tractor is stretched a few inches longer than the gas version so the bigger engine fit,
Denny Frisk
01-09-2002 07:41:59
 Re: Re: D-17 in reply to GeneD14, 01-06-2002 16:35:08
Sounds like a D-19!!!
