WC wheel seals
Brent a. Hansha
01-03-2002 18:02:00
I need some helping finding replacement front wheel seals for my unstyled WC.The parts stores in the area aren't much help. Thanks in advance!!
Joe M
01-03-2002 20:59:40
 Re: WC wheel seals in reply to Brent a. Hanshaw, 01-03-2002 18:02:00
They didn't use seals as you know them, they were heavy jute felt circles with heavy steel washers to back them up.
I believe the numbers are....
felt washer-70202104
steel washer-70202105
if you can find a dealer who sells TISCo Parts
they have a kit #208346 need one for each side
or a bearing & seal kit #228458.
I think these numbers have changed, but your dealer should be able to convert them, if not let me know & I will do it for you.
Tom
01-04-2002 18:53:41
 Re: Re: WC wheel seals in reply to Joe M, 01-03-2002 20:59:40
A couple of years ago my brother replaced the seals on his WC and if i remember he ended up with a kit to adapt new lip seals, probably a AC kit. I think there was and adapter that went in where the seal was, then a standard seal that fit the adapter. This may be what you end up with, better than the original I think.
