WD WD45 Block
Jeremy Owens
01-01-2002 15:37:36
Is a WD & WD45 MOTOR BLOCK THE SAME? And if so does the pistons go to the top? If anyone can help please e-mail me THANK YOU!!!
Carp
01-01-2002 16:00:24
 Re: WD WD45 Block in reply to Jeremy Owens, 01-01-2002 15:37:36
I believe that the correct answer is yes and no. They are different castings. The easiest way to tell the difference is the plate on the side of a WD block. A WD 45 does not have this large plate. The engine blocks will interchange between tractors thought.
Tom
01-01-2002 17:42:38
 Re: Re: WD WD45 Block in reply to Carp, 01-01-2002 16:00:24
On a WD the pistons do not go to the top. A 45, maybe with the power crater postons and more compression. I don't know. An socond thought a D-17 has more compression yet so probably a 45 piston does not go to the top.
