Oil leak. How do I fix it?
Dave Westlund
12-27-2001 12:26:05
I have a leak from the seals underneath my WD. How does the Power take off shaft come apart so I can replace the seals? IS it possible for someone to please post a copy of a service or parts manual for that area of the tractor? I'm not a mechanic!
All help would be greatly appreciated.
thanks Dave
BushogPapa
12-29-2001 06:34:44
 Re: Oil leak. How do I fix it? in reply to Dave Westlund, 12-27-2001 12:26:05
Sorry that NO-ONE is willing to be serious about your question..... . Yes, you do need the manual, BUT I believe you will be able to replace the seal without taking the entire PTO unit off.... You probably can pull the lower bearing out, with the stub shaft-BUT..... ... Have a BIG bucket ready.!! Use a good grade of Automotive Silicone--I use dental floss laid in a circle around the mating surface, in the silicone, and have not had any trouble with leaks...!! Use some common sense, and you don't always need the manual...
Duct tape!!!
12-28-2001 05:17:05
Sorry; couldn't resist that one!
KLF
12-27-2001 19:35:55
If you plan on keeping and using the tractor, I suggest you go out and buy the manuals you need.
