WD45 serial numbers
jim
12-24-2001 11:32:18
The plate on the engine reads "45 56172 G", but this does not correspond to serial numbers I find for that tractor. Do I have the wrong number, or is it a different engine?
Brian G. NY
12-24-2001 14:23:53
 Re: WD45 serial numbers in reply to jim, 12-24-2001 11:32:18
That is the engine serial number. According to the limited amount of engine serial numbers I have accumulated, yours is a 1955 WD-45. The tractor serial number will more accurately define the year of your tractor. You will find the tractor serial number on the LH vertical surface of the differential/brake housing. There is a machined "boss" located between the LH brake spring hole and the brake adjusting bolt/locknut. If you would, please let me know the tractor serial number when you find it so I can add it to my list of tractor vs. engine numbers. Thanks.
