Battery charger Positive Ground
Ironhorse
12-23-2001 18:08:54
Question is I have a postive ground tractor How do I hook the Charging cables up and how about jump starting also with a neg. ground batery
Thanks and Happy Holidays
Glenn(WV)
12-23-2001 18:50:49
 Re: Battery charger Positive Ground in reply to Ironhorse, 12-23-2001 18:08:54
The battery itself doesn't know if it's positive- or negative-ground. Connect the positive charger cable to the positive battery post and the negative charger cable to the negative battery post. I always disconnect the tractor's(car's, truck's) cables from the battery before hooking the battery up to the charger.
As far as jump-starting it from a negative-ground system, connect the negative jumper cable from the negative post of the good battery to the negative post of the dead battery. Connect the positive jumper cable from the positive post of the good battery to the frame(fender, etc.) of the tractor with the dead battery. Don't connect it to the positive post of the dead battery; you could get a spark and explosion.
