Weight of a B and Ca
Rick
12-23-2001 03:02:36
What does a Allis chalmers B mid 50s model weigh and what is the horsepower and what is the weight and horsepower of a 50s Ca. thanks in advance.
Ted Seifert
12-23-2001 13:04:31
 Re: Weight of a B and Ca in reply to Rick, 12-23-2001 03:02:36
B 1900 lbs shipping wt
CA 2850 lbs
B (early w/ 116 cu in BE engine Drawbar 12.97 HP Pto/Belt 15.68 HP
B (later w/ 125 cu in CE engine Drawbar 19.517 HP Pto/Belt 22.25 HP
CA Drawbar 22.97 HP PTO/belt 25.96 HP
Tom
12-25-2001 07:20:24
 Re: Re: Weight of a B and Ca in reply to Ted Seifert, 12-23-2001 13:04:31
I suspect the weight of the CA you quote is with loaded tires. It is basically the same tractor as a B, it has 4 speeds, probably a clutch in the right rear axle, and a different front end. Not much difference as far as weight goes.
Tom
12-25-2001 07:20:12
Nick (OH)
12-26-2001 07:18:20
 Re: Re: Re: Weight of a B and Ca in reply to Tom, 12-25-2001 07:20:12
With no fluid or weights my CA is just over 2,500 pounds and my C around 2,200. I have seen a B pull in the 2,000 pound class so the drivers weight was included in that.
