WD Cylinder Sleeves
Denny
12-18-2001 11:00:24
I have a WD with M & W cylinder sleeves and pistons that are 4 1/8" bore. Does M & W still exist? Where can you buy rings for these pistons? Are the seals at the bottom of these cylinders the same as those for regular Allis sleeves? What kind of lubricant is put on the o-ring seals for assembly?
Thanks in advance.
Don L.
12-21-2001 05:58:03
 Re: WD Cylinder Sleeves in reply to Denny, 12-18-2001 11:00:24
I am a M/W dealer. call 507 433 0073 I will be closed all next week.
Don L.
Austin Mn
Mark
12-20-2001 17:25:54
Antique Engine Company bought the M&W Co. call Craig Mc Adams 75 NE Venture Dr.,Ste A Waukee Iowa 50263 phone# 877-987-1118
Aaron
12-18-2001 14:49:15
I think M&W is still around, but I forget their name, and I think they sold the engine components to another company. I'm not sure about the o-rings, but I'd guess they are the same. As for a lube, I tried petrolium jelly and fought one sleeve for 2 hours. Talked to our AC mechanic and he said to use vegitable oil. Like canola, or corn oil. So, I put a thin coat on the o-rings and dropped all 4 in in under 15 minutes. No runs, no drips, no water in the pan.
Aaron
Kraig
12-21-2001 13:57:47
 Re: Re: WD Cylinder Sleeves in reply to Aaron, 12-18-2001 14:49:15
Do not use grease on the Orings. I use vasiline, it works good. I have heard of people using silicone gasket sealer (the blue stuff), but if you have to pull it out and try again, it might be a mess. Kraig
Denny
12-20-2001 09:24:26
Thanks, I'll try it. I felt it needed to be something very slippery to avoid pinching the rings.
