NEED HELP ON HD-15-AC 3523
MIKE MCK.
01-28-1999 14:53:14
I HAVE A CHANCE TO BUY THIS DOZER AND I WAS TOLD THAT IT SEEMS TO HAVE NO POWER BUT ENGINE RUNS GREAT. HE ALSO SAID IF HE PULLS THE STEERING CLUTCH AND HITS THE BRAKE THE MACHINE WILL STOP MOVING ALL TOGATHER WHAT ARE SOME THINGS THAT COULD BE WRONG
Lee Bradley
01-30-1999 07:53:46
 Re: NEED HELP ON HD-15-AC 3523 in reply to MIKE MCK., 01-28-1999 14:53:14
If the engine continues to run, when the tractor stops moving I would start with the master clutch.
The master clutch level should snap over center when ingaged. That is it will get harder to pull as you pull it back to engage the clutch until the last six inches or so of travel when it snaps back by its self into the engaged position. The level will push against your hand as it over-centers. It should take about 40 to 50 pounds pull to over-center the clutch if it pulls very easy the clutch needs to be adjusted.
Good Luck,
Lee Bradley
Brian Elliott
03-07-1999 13:16:56
 Re: Re: NEED HELP ON HD-15-AC 3523 in reply to Lee Bradley, 01-30-1999 07:53:46
When steering clutch is disengaged on one side and the other side stops pulling the steering clutch is slipping on that side.
Thanks,
Brian
