WC
WD45
Troy
12-16-2001 08:26:37
How do you tell the blocks apart from the WC and the WD-45 and the D-17? If it's by serial number does anyone have a list? Thanks
JMS/MN
12-16-2001 09:03:22
 Re: WC - WD45 in reply to Troy , 12-16-2001 08:26:37
Blocks on a WC or WD have a bolted on panel on the right side, whereas the WD45 is a solid casting on the right, no cover. I think the serial number on the lower left may also indicate a letter designation, but maybe only the 45 has that, I really don't know for sure. But if the right side does not have a panel, it's definitely a WD45 block.
Gary
12-17-2001 07:25:10
 Re: Re: WC - WD45 in reply to JMS/MN, 12-16-2001 09:03:22
You're right about the block,but you can't tell from the outside if its a WC/WD or a WD45 since all the 'enerds' are interchangeable
if a guy with a WC took his tractor to a AC dealership in 1957 with a busted block he'd probably would have gotten a block with no plate on the side.
JMS/MN
12-18-2001 06:15:34
 Re: Re: Re: WC - WD45 in reply to Gary, 12-17-2001 07:25:10
I checked my tractors since the previous post and found this The WD45 block serial number starts 45- and the D17 block serial number starts 17-
James
12-24-2001 09:38:11
 Re: Re: Re: Re: WC - WD45 in reply to JMS/MN, 12-18-2001 06:15:34
I have recently purchased an Allis-Chalmers WD-45 to begin restoration and unable to find the serial # for the tractor. Can you tell me where to look for this serial #. The # we have been able to find does not register as a valid serial #.
