Serial #
johnny hicks
12-16-2001 06:47:41
I HAVE WHAT I BELIEVE TO BE A 1948 WD-45. I KNOW THE WD-45 PART IS RIGHT, BUT I`M UNSURE OF THE YEAR. I HAVE BEEN UNABLE TO LOCATE THE TRACTORS SERIAL NUMBER. I HAVE FOUND THE ENGINE # MADE INTO THE BLOCK CASTING, BUT NO OTHERS. MY TRACTOR HAS APOWER LIFT AND ONE REMOTE HOOK UP. ANY INFO WOULD BE APPRECIATED. THANKS!
Brian G. NY
12-16-2001 15:17:25
 Re: serial # in reply to johnny hicks, 12-16-2001 06:47:41
Johnny, Look for the Engine Ser.# on the side of the block near intake end of the carb. If it's a WD, it will start with WD, If its a WD-45, it will start with 45. The Tractor serial number is on the LH rear vertical surface of the differential/brake housing. It will be stamped on a smooth area between the LH brake spring hole and the brake adjusting bolt/locknut and will be prefixed by WD whether the tractor is a WD or a WD-45. These stampings are sometimes pretty shallow so you may have to do some scraping with a wire brush and some solvent in order to read them. Please post your numbers when you find them as I am compiling a list of Tractor Ser.#s vs Engine Ser.#s just for fun. There is no (that I'm aware of) listing of Engine numbers by year but the Tractor number will tell you the year of manufacture. Brian G.
JMS/MN
12-16-2001 09:09:43
The first WD45's were made in l953, and the tractor serial number is located on the rear face of the differential housing, on the upper left corner. The transmission shift lever is curved, as opposed to the straight one on a WD, although some very late WD's did have the curved lever with angle cut gears in the trans. WD tractors were made 1948-53. Both had similar hydraulics, with lift arms and opportunity for a remote cylinder. The number on the engine block-left rear area, is the engine serial number. Serial number lists in various sources refer to the tractor serial number found on the differential.
