Help Identify Allis Tractor Model???
Emptypockets
12-13-2001 07:35:59
Have Allis, no serial plate that I can find on tractor or engine. There is a number stamped on transmission plate just below shifter (as refered to in book I have) and it is 224692 and just below the number there is a "G" casting. The only 6 digit serial numbers in book do not appear to be this tractor model (B, WC, WD, WD45. Am I looking in the right place? No numbers on rear differential as would be on a WD. I can send good pictures if you ask to help identify.
kevin
06-22-2003 12:55:54
 Re: Help Identify Allis Tractor Model??? in reply to Emptypockets, 12-13-2001 07:35:59
can any one tell me how to find out any info about my allis grader the only number I can find is BD3 - 994
Aaron
12-13-2001 18:10:46
Send me a picture. I can tell you what it is.
Aaron
steve
12-13-2001 16:44:41
the serial number of the smaller tractors B,C,CA is in front of the transmission selector, stamped into the case. You have too many digits. It should start with B,C,or CA and have 4 or 5 digits. This assumes your tractor a 4 cylinder motor, no frame, just a torque tube between the engine and transmission. radiator and engine in the front? the bigger older tractors have the serial number on the rear axle housing, and they have a c-channel frame around the motor transmission area..
Jim
12-13-2001 12:46:55
I have a number of books that may identify our tractor, so get apicture to me. And we will try to identify it
