B, to CA engines will they interchange
Super H
12-11-2001 20:56:24
Can anyone tell me if a CA Allis engine is the same as a B Allis engine
Bryan
12-12-2001 19:38:06
 Re: B, to CA engines will they interchange in reply to Super H, 12-11-2001 20:56:24
Can some one tell me how to tell which engine is which? I have what is supposed to be a CA but I am not sure the engine is original. Thanks
Dick L
12-13-2001 06:49:19
 Re: Re: B, to CA engines will they interchange in reply to Bryan, 12-12-2001 19:38:06
If you drop the pan and pull a rod cap, The CA will have a oil hole in the crank. The B's and C's do not. The first engine AM 2916 number had a 9 and was only on a few 1937's most 1937's did not have the Allis engine. AM 2916-10 started in 1938. I have two 1938's I have one 1939 and it has AM 2916-11. My 1941 C has AM 1916-13. I also have a 1944 B that has AM 1916-16 as well as a 1945 C that has AM 1916-17 . I sold a B this summer that had a CA engine and just bought a CA that has a C engine.
Dick L
12-12-2001 10:27:34
All the parts will bolt up the same from one to the other. The four 1/2" studs that hold the front end to the engine will have to be from a CA as they have a 5/8 thread in the block. The studs for a B and C have a 1/2" 13 thread going into the block.
Bryan Smith
12-12-2001 06:42:07
The B's started with the 125 cubic inch engine at sn 64501 in 1943. Anything earlier would be a 116 cubic inch engine, except the first 100 whihc were 113 cubic inch engines. If you don't know the year the B was made post the B engine's serial number (on the flange on the left side of the engine if I remember right) and perhaps we can compare that to those of engines on tractors we know the year of and help you out.
Ryan - IN
12-12-2001 06:06:01
They are the same block, different RPM. .the early blocks were smaller cubes, late were 125 cu. in.
