B oil pump gasket thickness?
David from Aust
12-02-2001 00:58:09
What is the gasket thickness for the oil pump on a model B. And does anyone in Australia know where I can get some implements for the model b tractor please. they must be in working condition or nearly working condition. thanks. Also, does anyone know of any Allis Chalmers Tractor clubs in Australia?
Peter Rumble
12-03-2001 20:01:09
 Re: B oil pump gasket thickness? in reply to David from Australia, 12-02-2001 00:58:09
Where abouts in Oz are you mate!
I have two 1948B Allis Chalmers that I am restoring, What about availabilty of parts over there..over here there is a guy in Auckland Andrew Lusty in Papakura if you cant find anybody there.
as to clubs I think that if you look for a vintage tractor club or even a stationary engine club you will be on your way to finding some like minded friends
David from Auzzie
12-04-2001 23:40:43
 Re: Re: B oil pump gasket thickness? in reply to Peter Rumble, 12-03-2001 20:01:09
I'm just west of Bathurst in New South Wales. Thanks for the info.
Dick L
12-02-2001 18:36:16
The paper gasket that goes between the pump cover and pump body and is packed in the gasket kit is .004 thick. I just opened and checked two sets and they were both the same.
Eric Egland
12-02-2001 18:15:06
Select gasket to give 1 to 3 thou. end play, rotor to pump cover. If end play is excessive, lap rear surface of pump body to bring back to spec. Good luck.
Tom
12-02-2001 15:20:20
Thin enough so you have only a few thousands of clearance I think.
dave
12-03-2001 16:51:12
 Re: Re: B oil pump gasket thickness? in reply to Tom, 12-02-2001 15:20:20
tom 1 to 3 thousandths according to manual specs if over 3 you can mill cover..... ..... .
