Data Plate?
ryan
12-01-2001 16:46:23
Can Anyone tell me were the data plate is on an older Allis-Chalmers tractor? Is there another way to identify it?
steve
12-01-2001 18:46:19
 Re: Data Plate? in reply to ryan, 12-01-2001 16:46:23
If it was made before about 1960 then you are looking at two different versions. The small tractors B,C,CA do not have a frame. The engine is connected to the transmission with a torque tube that forms the backbone of the tractor. The serial number is next to the shift lever on the trnasmission housing. If it is a bigger tractor like a WC,WD,WD45 then the numbers are on the rear axle around the brake rod.These tractors have a c-channel frame down both sided and in front of the radiator. If the tractor was made after 1960 it may be a "D" series and the serial number is on the engine bellhousing left side back corner of the engine. Narrow it down a little and repost for more help.
steve
12-01-2001 18:57:44
 Re: Re: Data Plate? in reply to steve, 12-01-2001 18:46:19
ryan, i forgot to mention that there is no data plate. you are looking for numbers punched into the casting. they are about 3/8 inch high numbers. Will start with C,B if by the transmission and WC or WD if on the rear axle.
ryan
12-01-2001 19:15:42
 Re: Re: Re: Data Plate? in reply to steve, 12-01-2001 18:57:44
I think it is older than 1960, the battery uses a positive ground and there is a crank starter on the front of the tractor. It is a large tractor, the thing that Ive never seen is it has only one front wheel (the front end looks like a heavy duty motorcycle style front fork). I will look for the info on the rear axle in the morning. Thanks for the help.
Bryan Smith
12-03-2001 08:53:04
 Re: Re: Re: Re: Data Plate? in reply to ryan, 12-01-2001 19:15:42
OK, let's identify it ....
(1) Is the seat centered, or is it off-set to the left side? If off-set see #2, if centered see #5.
(2) Does it have hand brakes? If so you have a WC. If not try #3.
(3) Does it have a hand clutch? If so you have a WD or WD45. Go to #4.
(4) Does it have a straight gearshift? If so you have a WD. If not you either have a WD45 or a very late WD. That's as far as I can get you on that set of tractors.
(5) Does it have a bench-type seat? If so you have a C. If it has a spring-loaded seat go to #6.
(6) Is the temperature gauge on the radiator poking through the top of the hood? If so you probably have a CA. If it's in a dash below the steering wheel you probably have a D series tractor - go to #7.
(7) Does it have a straight gearshift close in front of the seat? If so it's probably a D17. If it has a gearshift that curves out from under the seat it may be a D10, D12, D14 or D15. Go to #8.
(8) Is there a hand clutch allowing 2 speed ranges and an iron channel or frame support that runs along the side of the engine? If so you have a D14 or D15 (D17 also has this). If not you have a D10 or D12.
Whew! That's enough for a start. I'll bet you have a WC, WD, or WD45 from your description. Maybe one day I'll make a good key up for these to help ID them. Check the Allis Chalmers Images at the link provided - it may help you find yours. I just don't think the model U, A and other early ACs had a single front wheel option.
Bryan Smith
12-03-2001 08:54:56
 Re: Re: Re: Re: Re: Data Plate? in reply to Bryan Smith, 12-03-2001 08:53:04
I meant is the seat off-set to the right side! Some days .....!
ryan
12-01-2001 19:22:22
I forgot to ask, is the production date located somewhere on the tractor?
