hello, I have been in the process of upgrading my wd45 to make it a better working tractor.I have rebuilt the stock motor with oversize 4.125 pistons and sleeves making it 241 cid. I have added a 12 volt electronic ignition, fatter plug wires, D17 carb, and a LOT of massaging on the head. I am running 16.9x28 tires on combine rims and pretty much stock everything else. It starts, runs, and everything works good except for the foot clutch, but I have new parts to replace that as soon as I have time to install it. ( I use the hand clutch currently and it works fine) This winter/spring I want to increase the power even more so I can add more weight to the tractor and increase its pulling power/usefulness. and to run an additional Hyd. pump for two way operation and remote ports. Any ideas? I am thinking larger camshaft, flat-top pistons, D17 head, Stroker crank/rods etc. I want to have a solid well built dependable tractor, not a competition tractor. I am looking for maybe 65 hp. I figure I have probably 50 now. Any help would be great Thanks
