D14 shifting question
Chris Heiden
11-27-2001 14:04:19
Hey, When I shift my D14 to different gears sometimes I have to let the clutch up and press down on it again to shift into gear being careful not to grind the gears. What is the cause of this? Clutch? Transmission?
Chris
Dave Rote
11-30-2001 09:07:56
 Re: D14 shifting question in reply to Chris Heiden, 11-27-2001 14:04:19
There is nothing wrong with your clutch or transmison. The D-14s were hard to shift without grinding. I had several other people tell me the same thing. I put heavier oil (80-90) in the transmision, (I think the book calls for 30W) and this helped cosiderably.
Denny Frisk
11-28-2001 07:47:09
Sounds to Me like the teeth on the gears are keeping the gears from engaging. It's the nature of a sliding gear type transmission. Cars & light trucks don't do that as often because of the synchronizers used to shift gears. Sounds like Your transmission & clutch are fine.
