C engine rebuild ?'s
T.J.-N.J.
11-27-2001 06:20:10
I just tore down the engine from my 42 C, I pulled down a few bearing caps and see that the crank needs to be cut. I was wondering if anyone had ever had any experience with having their main caps milled down slightly and then line boring the block to do away with the bearing cap shims. I am sure that the rod caps could be done as well. I am also going to get the cracks between the cylinders fixed while the engine is at the machine shop.It just seems like a primitive way to set up your bearing clearances. Thanks T.J.
