Fotki photo hosting of the D-10 that refuses to run!!
ShepFL
11-20-2001 13:32:28
This is a test of a new photo hosting site. Free posting and unlimited storage. WWW.FOTKI.COM compliments of Tyler(WA).
For all the others - Duey(IA), GordonTN, D13, Joe Oligschlaeger and everyone else that has contributed I have may not mentioned HERE is the little beast from He!! that refuses to crank, much less start.
UPDATE
Wiring looks pretty good,
No hugh voltage drops anywhere
WHITE HOT SPARK at points
Will resume efforts aft T-Day
Mr. J
11-22-2001 14:13:17
 Re: Fotki photo hosting of the D-10 that refuses to run!! in reply to ShepFL, 11-20-2001 13:32:28
Shep,
I would try pulling that puppy with another tractor or truck and get the motor spinning, I mean flat out spinning. We have an Allis C that had a problem starting.....we pulled it one time really fast and it started then. And we haven't had any problems since... But, spin that puppy over really really good for awhile and see what happens. Good luck and keep us posted.
Bill from up north
11-22-2001 00:15:35
I went to start up a tractor -one day this summer at our museum -which had always been a good starter, and it wouldn't start. I played around with it for about 10min. ckecking spark, gas etc. and then like a bolt of lightning it hit me . It was turning over backwards. Somebody had switched the starters (colors didn't match anyway) . I'm thinking maybe you got a similiar situation and they sound almost the same cranking backwards.
Gary
11-21-2001 04:49:49
Just a guess but it looks like a new solenoid on the starter,some solenoids are energized by grounding some by hot side might want to check it
out.
Pete
11-20-2001 15:12:54
Shep, thanks for pointing out the photo sight...I am sure this has already been addressed, but did you do a compression check? Pete
kb
11-21-2001 17:54:19
 Re: Re: Fotki photo hosting of the D-10 that refuses to run!! in reply to Pete, 11-20-2001 15:12:54
Pete, I don't think Shep has had a chance to do that, as the starter is not turning the motor over.
