IB spark plugs
Randy
11-19-2001 09:32:58
I run my IB typically with a light load. I have a problem with the plugs fowling about every 30hrs. I thought I would try a hotter plug. Does anyone have any suggestions on what plug to use? Currently I use AC Delco R45. Thanks.
JDP
11-19-2001 19:47:40
 Re: IB spark plugs in reply to Randy, 11-19-2001 09:32:58
A hotter plug might work if you tractor is burning oil. The spark is the same, just the end of the plug is hotter in temperature. I would stay away from Champion plugs. Stick with the AC's, or Autolite would work too.
steve
11-19-2001 19:32:27
book says AC 45. my IB had Champion J12YC and seems to work o.k. but they always look a little black. Does the tractor use oil? rings might be getting a little tired. I agree a slightly hotter plug might help. I think that would be a AC 46 or 47. The AC47 was used in the distolate tractors.
