WD hydraulic cylinder problem figured out!
Plow Man
11-17-2001 21:22:45
Couple weeks back I posted a question about my WD's hydrualics settling. Well I put in new packing and tried it out. It lifted all the way up with no leaks. I was happy of this. But when I picked my plow up, a bunch of oil came out. So I went to look at it closer, and if I be d***ed, the cylinder shaft was up against the packing nut. It had a big hole down under the shaft. I looked in my parts book and found out there are 2 bushings before the packing, and I think strongly that they might be wore out, on both cylinders. Any thoughts welcome, I just thought I would say this:)
Dave in Mo
11-20-2001 09:33:31
 Re: WD hydraulic cylinder problem figured out! in reply to Plow Man, 11-17-2001 21:22:45
Thanks for the info. Are you using the Snap-Coupler system or do you have an aftermarket 3 point hitch?
Plow Man
11-20-2001 09:40:18
 Re: Re: WD hydraulic cylinder problem figured out! in reply to Dave in Mo, 11-20-2001 09:33:31
Neither. I have the old clevis type drawbar. I made two arms for the 3pt but never use a third center link. I just use the shredder so I want the arms to float up and down. I could maybe send you a picture.
