Alternator conversions
Jim Guarino, A
11-06-2001 03:57:56
We can advise on the various options of converting to an alternator, if you wish to contact us. An important item to remember is: the original generator was only rated at about 35 amps at the most, and the typical automotive alternator is rated at 60 amps or more. If the pulley ratios allow the alternator to turn fast enough to generate more than 35 amps, the original size wires will be overloaded, and will likely be damaged. See our web site: www.wiringharnesses.com
Tyler(WA) The old wires are fine
11-06-2001 09:33:07
 Re: Alternator conversions in reply to Jim Guarino, Agri-Services 716-937-6618, 11-06-2001 03:57:56
Given they are in good condition.... the old generator wiring should handle the new load just fine.
Old wiring was way oversized for the load because physical strength of the wire was more important than matching exact guage necessary.
Usually, you end up replacing some of the old wiring because it's just not needed anymore and easier to replace than re-use. When I upgraded my Massey with an alternator, I replaced 3 or 4 wires from my old regulator with one wire to the amp gage and one wire to the ignition switch. It sure would have been a waste of money to have purchased a new wiring harness for just two wires.
If you need a new wiring harness, buy one. But you shouldn't need a whole new harness to upgrade to an internally regulated alternator.
