D17 generator to alternator conversion
Scott G.
11-03-2001 20:14:12
I need to totally rewire a D17 series IV and I want to switch out the generator with a internally regulated alternator. I've done it before on a 900 series Ford but, I cant remember how I done it. Is there anyone out there with a good wiring diagram? Scott
Duey (IA)
11-04-2001 18:48:55
 Re: D17 generator to alternator conversion in reply to Scott G., 11-03-2001 20:14:12
Scott,
Maybe these will help out.
Duey
Duey (IA)
11-04-2001 18:48:40
Scott,
Duey
Glenn(WV)
11-03-2001 20:56:50
Scott, punch the link shown below. It will take you to Bob Melville's excellent article on 6v-12v conversions, which includes a schematic diagram. It was originally written for a Farmall M, but it should work for your D17. HTH
Scott G. (MO)
11-03-2001 22:08:19
 Re: Re: D17 generator to alternator conversion in reply to Glenn(WV), 11-03-2001 20:56:50
Thanks Glenn Scott
steve
11-04-2001 17:06:44
 Re: Re: Re: D17 generator to alternator conversion in reply to Scott G. (MO), 11-03-2001 22:08:19
just remember to change over the battery cables. all alternatoirs are negative ground systems. the no 1 terminal on the delco must be switched off when engine not running. the drawing referenced is good. the dropping resistor does a good job of making the alternator charge better. i use a 10 ohm, 10 watt type. buy at Radio shack for $2.
