D-21
johnson
10-31-2001 20:37:45
I was wondering what years they made a d-21 and what could i do to make this tractor pull? Thanks
Bill from up north
11-02-2001 17:42:29
 Re: D-21 in reply to johnson, 10-31-2001 20:37:45
How much do you want? I worked for an Allis Dealer when those tractors were new. We unloaded one brand new off a rail car ,did the predelivery check and then put on the dyno. We quit testing at 175hp. cause we were afraid the dyno was going to flip over-(it was supposed to be anchored over 150hp.) using a 540shaft. If you turn up the rpm to 2700 and open up the pump you will easily get 200hp. Just don't try to use that horsepower going in a circle or the back end will self destruct unless it has had the change up set of bull gears and pinions and you can tell that by removing the top rear cover. If the final drive housings have grinding marks on both sides to allow the installation of the wider gears ,and the gears are just about the same width as the hole(nobody ground more off than they had to and it was a forty hour job as it was) then its had the change-up. This was a factory kit. I don't advise running them at that hp. on the light gears.
C.B.(MO)
11-04-2001 15:59:39
 Re: Re: D-21 in reply to Bill from up north, 11-02-2001 17:42:29
does the 210 have the weak gears too? would like to find out before the pull not during
Bill from up north
11-04-2001 18:54:59
 Re: Re: Re: D-21 in reply to C.B.(MO), 11-04-2001 15:59:39
I not aware of any problems with the 210. That next series of tractors after the 21 were all beefed-up. In 1967 the D21 was probably the most powerful 2WD tractor on the market. Most of the dealerships didn't have dynos and a lot of those tractors hit the farmyards putting out way more than they should have been- I don't know why or how they getting out of the factory like that. They soon found the weakest parts and it sure wasn't the engine.We had guys come back and trade up to a 7030 and were mad because it wouldn't pull what their old 21 would.
But by then Allis had put the lid on- 5% over rated hp. and that was it.
MADDOG
10-30-2002 11:53:46
 Re: Re: Re: Re: D-21 in reply to Bill from up north, 11-04-2001 18:54:59
Bill, you are SO correct; Allis Chalmers was always known for building tractor engines that the
driveline wouldn't support (unless the Ops Manual was
STRICTLY followed). You are correct in that the AC D-21 were (and still are ) the strongest pulling 2-WHEEL drive tractors around. One of my (2) D-21s pulls 185 PTO horsepower on my CALIBRATED DYNO; I rebuild piston (turbo)engines for a
living. I built a 205 PTO HP D-21 for a guy up near Salem; he has NEVER been beaten in a formal tractor pull; I made him sign paperwork that he won't tell DETAILS on his engine; he just laughs all the way to the bank!!
D-21
11-03-2001 07:05:09
Thanks Bill,
This d-21 has no pto and just had a new pump and turbo and cluch and it is running about 3,000 rpms and i will check the rear end thanks. Any ideas on the hp?
Bill from up north
11-03-2001 19:38:46
 Re: Re: Re: D-21 in reply to D-21, 11-03-2001 07:05:09
We had a sevice call to one that was out in the field and had quit. It had no pto so we couldn't test it before it left the dealership. The guy was pulling a seven bottom 16"plow with a pony press and packers at six mph. We tried to start it but you could tell it had no compression ,so we pulled the valve cover off and found all the push rods bent. Our guess is that it got the valves so hot that they stuck and bent the push rods. So we ordered a new set of push rods and went bck out to it a few days later . Meanwhile I got a brainwave and decided to test one we had on the lot with a pto. I installed a pressure gauge on the intake and checked turbo pressure under load .I found out that those engines put out about 10hp. per lb.of boost ie.15lb.pressure -150hp. When we went back to this other tractor we took a gauge with a hose and ran it back to the cab.After we put in the new push rods,reset the valves etc.,we tried it out. The pressure was running between 16 and 17lbs. all the time .The customer wasn't real happy when he found out we had dropped it back(turned the pump down) until we had only 14lbs.max.boost -he had to drop a gear or raise the plow but hey the tractor was only rated for 127pto.- and was getting a deal at 140hp.and that was the max that the Company Service Rep. said we should let them out at. So all I can say is take a pressure reading and it will give you a good estimate because I'm not sure what happens with the extra rpm buts its bound to create more hps.and more boost pressure. MY bet is it'll be in the 20's
d-21
11-03-2001 20:09:55
 Re: Re: Re: Re: D-21 in reply to Bill from up north, 11-03-2001 19:38:46
Dear Bill do you have any ideas on how to make this a hot puller like changeing heads or pumps ect. I would like to know more because i am new at this pulling and allis thing
ThANKS
Bill from up north
11-04-2001 18:16:45
 Re: Re: Re: Re: Re: D-21 in reply to d-21, 11-03-2001 20:09:55
Sorry- I was working at a dealership so everything we did was strictly stock. We had one of our own D21's at a local pull a couple of times -years back -they didn't have a lot of classes,but we got second in efficiency. We were beat by a 900 Versatile 4WD with duals all around and all we had was the big singles,full of fluid. Pulled through the first time and dug two big holes in the hard pack in first high at about 2700rpm. We had just driven it from the field to the carwash,to the pull. All I did was open up the high idle screw a little and away we went.
