WD-45 OR D-17 CRANK IN WD.. WILL IT WORK
POPPIN 60
10-31-2001 19:17:51
I WAS WONDERING IF YOU CAN PUT A WD-45 CRANK OR A D-17 CRANK IN A WD BLOCK WITH OUT ANY GRINDING ON THE BLOCK. THANK YOU
Aaron
10-31-2001 19:41:56
 Re: WD-45 OR D-17 CRANK IN WD.. WILL IT WORK in reply to POPPIN 60, 10-31-2001 19:17:51
You can put a 45 crank in no problems, but a D17 crank won't fit without some serious grinding on the block and caps. Both have the same stroke, so go with the 45 crank and you'll be fine.
Aaron
