Magneto and governor trouble!
Peter
10-27-2001 12:58:56
I have a 1948 Allis B that had a Lucas magneto (just a shell) with a coil assisted start and the governor unit was just the bare minimum with the guts missing -looks like it just provided rotation for the magneto. they had a foot accelerator! It is 12 volt wired. Any way I have replaced the lucas with a FMJ and fitted a working governor unit. problem is now I have an extra wire (the one that went to the coil and am not sure how to wire it up now...and the wiring diagram I have looks like it is for a 6 volt?
I have tired starting her after and seem to be getting nowhere... I NEED HELP !
can you guys suggest any thing!
steve
10-27-2001 16:37:43
 Re: Magneto and governor trouble! in reply to Peter, 10-27-2001 12:58:56
Peter, the magneto has the coil inside. therefore there is no wire. mag does not need a battery to start. works like a push lawnmower. if you have an old 12 volt coil, with the wire to the battery and a spare wire to your old mag, you can remove the whole thing. just run the new mag cap wires to the 4 plugs. there is a small terminal on the side of the mag. this is the kill switch, if you touch it to ground the spark will stop and motor die. if you acutally have a new MAG and not a distributor, then you need no wires at all.
Duey (IA)
10-27-2001 15:50:30
Peter,
Check out these wire diagrams to see if they will help out. Duey
Peter
10-27-2001 18:32:56
 Re: Re: Magneto and governor trouble! in reply to Duey (IA), 10-27-2001 15:50:30
Hey Duey!
The wiring diagrams are excellent!
I have one question..in reference to the plan labelled magneto...there is a wire shown as going from the magneto to the ign switch...can anyone tell me where it plugs into the mag..I cant seem to find a spare hole???
can you help...
regards Peter
Duey (IA)
10-28-2001 09:13:37
 Re: Re: Re: Magneto and governor trouble! in reply to Peter, 10-27-2001 18:32:56
Peter,
On the side of the mag is a small terminal bolt. Some have a small tab on this that is used to short out this terminal. The wire fastens to this terminal so the switch can short out this terminal. Duey
Norman(ID)
10-27-2001 21:21:33
That wire Connects to the kill switch on the mag and the other end connects to the on-off switch on the control box under the steering wheel.this allows you to stop the engine from the tractor seat.
