7000 clutch shaft
val
10-27-2001 11:38:24
Just split my 1976 7000 this morning to replace the clutch. The clutch shaft is worn down .030 on the diameter that goes into the pilot bearing. Per my IT manual, I need to remove the shaft through the rear of the torque housing. I don't want to go through all the work of splitting the torque housing from the rear end. Any good ideas?? JB Weld?? Will a sleeve with a .015 wall thickness stand up??? Thanks!!
