Electric start conversion
R. f.
10-24-2001 13:20:51
Has anyone spent the time or money to convert your crank start "B" to an electric start? Yes, I know how expensive it can be. Any tips would be appreciated. Can the block drilling of the two generator mounting holes be tricky. Any help? R.F. Michigan
Dick L
10-24-2001 18:53:10
 Re: Electric start conversion in reply to R. f., 10-24-2001 13:20:51
I changed one over this last spring. I swithced the torque tube and block. Not that big a job. You need to find a parts tractor that has a good block and torque tube, with most of the rest shot to get by the cheepest. They are around, watch the farm auctions.
Tom
10-24-2001 17:41:29
If you only use the battery for starting it will last a long time before charging is required. Just charge it once a nonth or week as necessary and forget abut the generator and all that stuff. An engine will run a long time on a battery too even if it is being used for ignition.
Johnny in E.Tx
10-24-2001 17:57:45
 Re: Re: Electric start conversion in reply to Tom, 10-24-2001 17:41:29
I have a Farmall A that I am going to convert to electric start. It has a magneto and I'll do just what Tom suggests, battery only and no charging system, also worked quite well on a WC I once had.
