Allis c
matt preston
10-21-2001 18:28:54
i have a c on the tractor it says tractor number c1182 is this the model and serial or what if not where do you find it this was right next to the base of the steering collem i think it was dark and did not have time to find out other numbers and how many lugs it had but it is tricicle front end
steve
10-21-2001 20:02:09
 Re: allis c in reply to matt preston, 10-21-2001 18:28:54
Yes it is a model "C". If it only has 4 digits after the C, 1182, then it is a 1941 model. The tractors normally had tricycle front end, 6 volt battery if it has a starter. (may be crank start). might be magneto ignition. the later model years had distributors (and battery). the tractor should have a three speed transmission, and weight is about 2500 pounds. it may have a hydraulic valve on the back end, right side of the PTO housing. the hydraulics run about 3500 psi, but very low volume. it may have a pto shaft sticking out the rear (540 RPM) and a second belt shaft PTO sticking out the left side of the pto box. this shaft runs about 1100 RPM. the PTO is not live. the engine clutch has to be engaged to make pto spin. If you have a starter on the engine, the battery would have been 6 volt positive ground. no starter= no battery.
