Joel Thomas
10-20-2001 17:00:57
Here are the serial numbers off of the tractor in question.
the engine's serial number:
WD339212PA
The right side rear geared hub:
AM3834-7
he said that is all he could find on the tractor.
(so I know it has a few paint jobs on it.:)
he said the span on the back tires was 10feet
and he said the tires come up to his neck and he is 6'2"(all are his words over the phone).
I know they could have put bigger tires on though.
thanks,
Joel Thomas
Wolf Bayou,AR
Brian G. NY
10-20-2001 17:17:10
 Re: Serial Numbers in reply to Joel Thomas, 10-20-2001 17:00:57
The engine serial number identifies it as a WD; probably an early '53. The tractor serial number is located on the LH vertical surface of the differential, just below the brake spring hole and above the brake adjusting bolt/locknut. There is a smooth machined surface there with the number stamped into it. The number will be begin with WD followed by six digits. There is a listing of starting serial numbers under "research and info" to the left of this screen. The numbers are off a little but "close enuf for gov't. work".
Joel Thomas
10-20-2001 17:15:37
I forgot to add that it has a single wheel in the front not tricylce but just one wheel.
Thanks
Joel Thomas
Wolf Bayou,AR
Jodie
10-22-2001 20:58:42
 Re: Re: Serial Numbers in reply to Joel Thomas, 10-20-2001 17:15:37
Just some more information for you. According to my books there were 146,525 WD's made. Of those, only 1074 had a single front wheel.
