Injector pump on 200 allis
john
10-14-2001 13:59:16
ok guys, i need your help on how to get a washer out of the hole where the injector mounts in. one of the guys i talked to said to not spray it with wd-40 another said to andif that doesnt worktotake a punch and beat around the edges of it. if your supposed tobe careful with it how can you do that? thanks for your help in advance guys.
john
Gleanersnitzle
10-17-2001 18:16:16
 Re: injector pump on 200 allis in reply to john, 10-14-2001 13:59:16
In the past I had a dual wheel hook that had left handed threads on it and was the right size to fit the inside the copper washer. Screw it down in there and poof it screws itself out
C.B.(MO)
10-14-2001 18:18:54
on my 210 I ran the engine with the injector bolts just loose enough to let it move a little,the fuel and heat loosened the copper washer. worked for me
john
10-14-2001 18:39:36
 Re: Re: injector pump on 200 allis in reply to C.B.(MO), 10-14-2001 18:18:54
thanks CB now all i gotta do is put the pump on and i will try your suggestion. if it doesnt work do you have any more? what ever come of your 210? did you get it to start? was it compression?
john
C.B.(MO)
10-16-2001 06:00:35
 Re: Re: Re: injector pump on 200 allis in reply to john, 10-14-2001 18:39:36
wasnt a compression problem,had the supply pump on inj pump rebuilt,was starving for fuel at real low rpm. the reason i pulled the injectors put a d21 head on a 210 and 210 injectors open at higher pressure,only had one copper washer stuck
kirk
10-14-2001 19:50:34
If you take a screwdriver and grind a hook-like curve in it on the side so you can put it into the hole and hold side pressure on it as you jerk it out of the hole it will hopefully catch on the edge of the washer and break it loose.
See what happens and good luck
Kirk
