Starter Repair
Farmer John
10-13-2001 09:10:42
How do I go about replacing my starter? And what do I tell a parts house Im looking for as far as a replacement. Symtoms are a clicking noise when I try to start it. But not a rapid clicking like a bad battery. Just a single click from the starter silinoid which I replaced and it still makes the same noise. Would you replace starter or is there another alternative. Thank you Farmer John
Scott KS
10-13-2001 20:33:31
 Re: Starter Repair in reply to Farmer John, 10-13-2001 09:10:42
Check your terminals from battery and starter. may just be a loose connection or corroded terminal. Feel the wires wiggle them and bend them around to see if the large wires are broken under the insulation. Bad connections will give you a click and no spin on starter. As the saying goes clean, bright, an tight Good luck and let us know how u make out.
Scott
Steve from Tn
10-13-2001 15:50:51
Hey John, I don't know what kind of starter you have but I would try a starter solenoid. That's the thing that you use to pick up the starter with. Looks like a little bitty starter hooked to the big un. They are usually around $15-$20. It depends on the size tractor and scarcity of the parts and such. You probably have a starter rebuilding shop fairly close to you. I have at least 2 within 25 miles. Those guys can usually tell ya the problem and fix it up pretty fast. Hope this helps you.
C.B.(MO)
10-13-2001 19:41:09
 Re: Re: Starter Repair in reply to Steve from Tn , 10-13-2001 15:50:51
does the starter turn? if not try shorting across the two big connections on the back of the solenoid,this should let the starter turn without engaging.if it does'nt spin theres a starter problem. if does spin solenoid is bad. but make sure tractor is out of gear first . just because something is new does'nt mean it is good. I have bought solenoids that were bad and starters too.
