Help,what engine is in my WC
Joe Wise
10-12-2001 10:31:44
I am trying to get the valve spring keepers for
the exhaust valves on my WC.The Allis dealer has
sent me the wrong size parts twice now,the problem
is on my head the exhaust valve springs are smaller than the intake and use a thinner keeper. The dealer says on any WC they are all the same
size.My tractor s/n is WC45907 a "36" unstyled
magneto ignition,hand crank only. The s/n stamped
at the rear of the engine is W45998K,the number under the magneto is U8019-10.There is no s/n on
the head or the carb side of the engine.
Thanks for your help,
Joe
Bama Dee
10-13-2001 07:18:51
 Re: Help,what engine is in my WC in reply to Joe Wise, 10-12-2001 10:31:44
Joe, I think somewere along the line, somebody did a valve job on your engine, and used different valves. One of my WCs' ( with s/n close to yours ) has two odd valves/springs similar to what you discribe. By the way, the K at the end of the s/n means the engine is a low compression version which will run on Kerosene, also known as a dual fuel model.
Joe Wise
10-14-2001 19:49:41
 Re: Re: Help,what engine is in my WC in reply to Bama Dee, 10-13-2001 07:18:51
Bama Dee,
Thank you for your reply,that would explain it,I will replace the valves and springs back to the original set up.
Joe
