Allis Chalmers B
Ian Schedler
10-10-2001 16:01:38
I much dose a AC B weigh.
Zeus
10-12-2001 13:49:32
 Re: Allis Chalmers B in reply to Ian Schedler, 10-10-2001 16:01:38
Allis-Chalmers B:
shipping weight 2,060 lbs
unballasted weight 2,199 lbs
ballasted weight 4,193 lbs
(Source: Allis-Chalmers Farm Equipment 1914-1985 by Norm Swinford)
Jerry Coulter
10-12-2001 12:13:23
The last line on page 5 of my 1939 AC B operators manual says "Weight With oil, gas and water, and Hydromatic tires - 2160#." It shows 8.00-24 tires which would hold 165 - 175 ballast in each tire. This tractor came with no electrics or PTO.
A 1968 used tractor price guide says the tractor weighs 2126 lbs including PTO, starter, generator and battery. This shows 9-24 tires containing 229 - 242 lbs ballast in each tire.
I feel certain these 2 sources used different scales!
Dick L
10-11-2001 07:56:00
I have two that I have pulled in the 2000# class without wheel weights. They have to be in the area of 1800# without a driver.
darrell cogins
10-10-2001 16:20:35
I have a model b and it could not weigh to much I would say about 1800lds I can puch my a/c around with no problem but when i add the plow on it add about exter 300 lds or less
kb
10-10-2001 18:33:39
 Re: Re: Allis Chalmers B in reply to darrell cogins , 10-10-2001 16:20:35
My brother-in-law has hauled B's on the back of a half-ton pickup. They squat the truck down, but ride just fine. The front wheels of the B are slightly wider than the distance between wheel wells, so one wheel has to be run over a wheel well to load it.
