WD 45 brakes
Glenn Deckert
10-08-2001 20:49:42
I'm looking at a WD45 for purchase and the broker handling the sale states that the tractor has almost no brakes. He thinks that the brakes do not need replaced, but just need to be adjusted. Does this sound likely, and if so, what steps would I need to take to adjust the brakes on this tractor. I'd appreciate any advice that anyone can offer. Thanks, Glenn
Ted Seifert
10-09-2001 09:35:20
 Re: WD 45 brakes in reply to Glenn Deckert, 10-08-2001 20:49:42
Be careful there may be oil on the breals indicating that there are bad seals.
Brian G. NY
10-09-2001 06:25:13
I'd pull the brake inspection covers and look at the condition of the brake shoes and drums. There are only two bolts on each cover; the left one is real easy and the right one only slightly difficult in that it also serves as the seat bracket/hinge.
jim
10-11-2001 20:13:18
 Re: Re: WD 45 brakes in reply to Brian G. NY, 10-09-2001 06:25:13
Remove the inspection covers first and check the condition of the brakes and the drum. From my experience usually the shoes are worn, and need new linings (the easy part). Now the hard part, removing the pins under the rear end housing that hold the shoes in place, Sometimes this is a challenge. Good luck!!
