WD hydralic problem
Jim
10-08-2001 16:40:25
Help! All of a sudden I get no action at all from the hydraulic on my WD. The linkage seems fine, but nothing happens when I move the lever. What could be the problem? Thanks much.
C.B.(MO)
10-09-2001 17:35:21
 Re: WD hydralic problem in reply to Jim, 10-08-2001 16:40:25
I would remove the hyd control valve to see if the pump is pumping,since is just a couple of bolts. should'nt even have to take it all the way off, just loosen the bolts a couple of turns,then crank the starter a little . if oil comes out, then check the valve. good luck
Kemper
10-08-2001 17:33:50
Jim, This may be a silly question but,is it full of hydraulic oil? i can't think of anything that would make it quit pumping,unless one of the plungers or valves in the pump stuck.
Jim
10-09-2001 16:47:52
 Re: Re: WD hydralic problem in reply to Kemper, 10-08-2001 17:33:50
Checked the oil and it's fine. What would be the next move?// Thanks
Jim
10-09-2001 16:47:18
C Tucker
10-10-2001 19:43:43
 Re: Re: Re: WD hydralic problem in reply to Jim, 10-09-2001 16:47:18
I had the same problem 2 years ago. Come to find out the shoulder on the relief spool was broken clean off. That let the pump dump all the time. A new spool from Agco was installed,but the new spool wasn't machined properly and it wouldn't by-pass. After removing the pump,counter boring the spool to the proper dimensions,and relacing it for the second time it worked ok.
