WC Shifter how to fix?
Bunky (MI)
10-07-2001 18:54:28
i have a WC and the shifter is loose I heard there is a way to tighten it up can anyone tell me what i need to do ????? ????
Butch (OH)
10-08-2001 11:04:49
 Re: WC Shifter how to fix? in reply to Bunky (MI) , 10-07-2001 18:54:28
Bunky, The rotation (slop) stop is a pin in top left side of the shifter tower that engages a corresponding groove in the shifter pivot ball. Three things happen, the pin wears, the hole in the tower wears, and the groove in the shifter pivot ball wears. The shifter pivot ball is hard and is likely the least worn part, which is good news because it would be hard to repair one without machine tools. The hole in the tower can be drilled out if need be and a new larger diameter pin can be fabricated from a grade 8 bolt. If you are real lucky and the only thing wrong is the pin is broken or worn (not likely) you should be able to get one from AGCO. I have also seen devices attached to the outside of the tower. I don't know if they were an aftermarket kit or field engineering.
