Allis Chalmers Model C
Floyd Johnson
10-03-2001 19:04:15
I would like some help in getting the right locations for the decals on a 1948 model c-allis can anyone help thanks. Floyd
Jodie
10-04-2001 21:15:03
 Re: Allis Chalmers Model C in reply to Floyd Johnson, 10-03-2001 19:04:15
According to my research, the Allis Chalmers decal should go 4 inches behind the front of the hood and 3/4 inch above the hood beading. The C decal was actually never used by Allis. Newer sets come with them and many collectors use them. If you choose to use it, it should go just in front of the bottom bolt that holds the hood in place about 1/4 inch in front of the seam. The center of the C should be at the same level as the bolt. The radiator crank decal goes just under the handle for the crank. The PTO guard decal goes 1 3/4 inches in from the inside lip of the shield. The oil filter decal was really printed on every filter. Since you change filters you may choose not to use this or to use it for a special show tractor that does not get the filter changed as often as a working tractor. I am sure I have left out several decals because I don't have a set in front of me. Let me know what I forgot and I, as well as others on this site, will try to help.
