WD Transmission noise-1st and 2nd gears
Brook
10-02-2001 06:32:18
Given the OK from my wife to get another tractor. I told her it was for our 4 yr old. Maybe I'll get her one next..lol Anyway the WD I looked at growled and raumbled in 1st and 2nd gears. Third and fourth gears sounded fine. Noise stopped when clutch was pushed in and it seemed to shift OK. A local mechanic said it could be as little as bearings for those two gears and that just might be the tip of the problem.
My question for everyone is...What could be the best and worst case scenario to this problem?
The seller wants $2000 for WD, all hyd.loader and a Charlynn PS unit and pump thrown in to boot. The package as it stands sounds ok, but I'm interested what the transmission noise holds in store for me. Thank you for input
Dave K (Fl)
10-14-2001 09:04:46
 Re: WD Transmission noise-1st and 2nd gears in reply to Brook, 10-02-2001 06:32:18
The WD (not the WD-45) has straight cut gears and they are noisy. You also want to be certain the right lube is in the tranny. The price is kind of high I think, but the noise is probably not a concern.
Dave
Dave in Mo
10-05-2001 09:20:01
My WD whines and runs fine. Try the tractor out by pulling a heavy load. Don't be afraid to load it up and try it out. It'll give you an indication of how the two clutches are also. Two grand may be okay if the loader and pump are mounted. Better have real good rubber too at that price. I'd probably low ball that number myself especially for a narrow front end. My 2 cents worth.
Don
10-04-2001 13:35:05
I LIVE IN NORTHERN WISCONSIN AND THERE WERE QUITE A FEW WD/WD 45 TRACTORS IN MY AREA.THEY HAD A REPUTATION FOR HOWLING TRANSMISSIONS.MY DAD'S WD MADE A LOT OF NOISE IN 1ST AND 2OND BUT IT NEVER CREATED A PROBLEM FOR HIM.THE NEIGHBOR HAD A WD WITH THE SAME PROBLEM AND HE ENDED UP REPLACING BEARINGS IN THE DRIVELINE.THE SITUATION IMPROVED BUT DID NOT ENTIRELY DISAPPEAR.UNFORTUNATELY I DON'T KNOW EXACTLY WHAT HE DID.
