Value of a 1955 WD45
Brewster
09-28-2001 20:17:12
What is a WD45 worth with a wide front and side mount sickle bar mower. Tractor needs rear tires and wheels, paint, battery box and muffler. Seems to run ok.
Dan
09-30-2001 05:18:49
 Re: Value of a 1955 WD45 in reply to Brewster, 09-28-2001 20:17:12
You got good info from Lazyhorse. I recently paid $1100 for a WD and that was too much for its condition. The 45 painted up nicely with wide front,new rubber/rims and mower should bring $3500-$4000. Work backwards from that. I put new rubber and power-adj. rims on WD for about $650. New muffler $25. Battery box $60. If you paint and do metal work you can save a lot. I did not use an expensive paint on my WD. I had an estimate of $1500 on blasting and painting. I ended up doing some myself and having fenders, hood and tank done by someone more professional. Looks good now. Incidently, above costs leave you around $1000-$1200 for tractor if metal is good and it runs good.
LazyHorse
09-29-2001 06:18:55
Prices on most tractors vary widely depending on what part of the country, and condition. Here in east central Indiana, Iv'e seen WD45's go for between $800, and $2500 for a good runnning tracto in decent shape.
