WD-45 PTO parts
Chad Penny
09-26-2001 06:00:30
Looking for possibly a complete PTO unit, Brush hog has it warn out. Need for sure the PTO shaft from the gear box to the rear of the tractor. It is all warn out from wrong size pins.
May need new PTO Shaft out of gear box. Please let me know if any one has any info on this
Thanks
Chad Penny
bob hough
09-26-2001 06:27:09
 Re: WD-45 PTO parts in reply to Chad Penny, 09-26-2001 06:00:30
If you would like you can send them to me to be rebuilt. I do this work all the time and have good results. I build up the shaft and turn it back to standard and cut the collar off the pto shaft and build a new one. When its done can't tell it from a new one. Thanks Bob
Peter Hatlestad
09-27-2001 19:38:46
 Re: Re: WD-45 PTO parts in reply to bob hough, 09-26-2001 06:27:09
Bob
I have a PTO shaft from a WD45 that needs refurbished also. How much do you charge to redo one?
Peter Hatlestad
Ric Meixell
10-03-2001 05:27:51
 Re: Re: Re: WD-45 PTO parts in reply to Peter Hatlestad, 09-27-2001 19:38:46
I have a similar problem. I replaced the shaft out to the rear but the hole on the stub shaft is worn out probably .100". I have it jury rigged for now but would like to get that shaft rebuilt. Can you provide a cost and turnaround time for your repair. Most of them in junk yards are worn in the same manner.
