AC Model B Steering Adjustment
Doug fm Duluth
09-24-2001 14:05:55
Can anyone tell me how to take the slack out of the steering box? Linkage was checked. Am confident it's in the steering box. In advance, thanks!
steve
09-24-2001 14:38:37
 Re: AC Model B Steering Adjustment in reply to Doug fm Duluth, 09-24-2001 14:05:55
there is an adjustment screw and locking nut on the right side directly opposite the lever pivot shaft. this pushes the shaft into the worm gear (column) to take up the slack. You can try this, but dont be suprised if it does not hlep much. Do you have tight spots and sticky spots when turning?? The pivot arm that hangs down fromt eh box has a steel pin that rides in the column work gear grove. It is not uncommon for the pin to be wornout causing the slop. Will have to remove the sheetmetal, splined drop arm, then open right side of steering box to see everything. Remove gas tank first.
