WD power steering pump location?
Plow Man
09-21-2001 19:43:07
Is it possible to run a hydraulic pump from the same drive belt? Like could you put it over the govenor with special made brackets? Or would the water pump pulley not have enough belt going through it to drive the water pump? If anyone thought of doing this or changed thought, please leave a post. Thanks.
Dave Grubb
09-24-2001 07:24:36
 Re: WD power steering pump location? in reply to Plow Man, 09-21-2001 19:43:07
I think to get enough belt tension for the hydraulic pump you would be putting too much load on the water pump bearings. For my power steering project I am going to mount my alternator above the water pump, mount a Ford power steering pump with its integral reservoir at the old generator mounting area, and of course use a dual groove crankshaft belt pulley. One groove of the belt pulley drives the water pump and the other drives the alternator and power steering pump. I chose this arrangement because the alternator never needs to be looked at and the power steering pump fluid level does need to be checked from time to time. Also with the pump reservoir located at the old generator mount area it gets plenty of cooling air flow from the fan. Power steering fluid temperature should not exceed around 180-190 degrees. Another guy posted a message about mounting a hydraulic pump onto the engine front support angle underneath the engine. This woud be a good hard point to mount a hydraulic pump also.
Duey (IA)
09-21-2001 20:50:59
Plow Man,
Char-Lynn uses a seperate add on pulley for the crankshaft to drive the steering pump with a seperate belt. My guess would be a lot of belt slippage if the generator, water pump, and steering pump were all on one belt!!! Duey
